The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
You're apparently using a lens with an aperture ring. Turn the ring to its smallest opening (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring. If this doesn't do it, please reply to this post specifying the lens(es) you're using.
Turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it. Control the aperture from the camera, just as with other lenses.
If you get an "E" after loading the film it means that the camera is still Empty and the film has not loaded properly. The most common cause is that the leader has not been pulled out enough past the red mark. I also like to place a sprocket hole on a sprocket tooth (I assume here that the N80 uses a sprocket drive system like other Nikons). When loaded properly the film should advance to frame #1.
Your "FEE" error is something else again and has nothing to do with the film. Apparently the film was properly loaded if you got that also. "FEE" is an aperture error which you get most commonly when you are in one of the auto modes (P or S) and you don't have the lens aperture set to the smallest aperture (largest number, usually f22). Set the aperture ring on the lens to the highest number.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
That means your lens is not set to the smallest aperture - f/22 or f/36. Turn your lens aperture ring all the way to set the smallest opening. Then the error will go away.
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again.
The fEE error message
Set to f22, or the highest aperture
number - normally marked in orange.
Note the locking switch.
