Hotpoint ultima, fills with water then stops with H2O flashing in the display
If the flow at the inlet valve is good and then the water comes into the system. Now if the WATER LEVEL SENSOR - normally a pressure switch- does not activate at the preset/chosen level to give the signal to the program controller to switch off the INLET VALVE , it will overflow. So the fault is the water level sensor and showing the error H2O.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
