Check the electrical connections for you control switches...there should be at least two of them. Disconnect them and see if there are any recessed pins or dirt. Do this several times as there may be some oxidation on the connectors and doing this will help clean them off. The radio and door light works of the small limit switch on your door frame. Everything else works through the operators window/door lock control panel.
you have a short between your lighting and, window circuit
this can only be inexpensively repaired by an auto electrician. please do not put in a larger fuse! this can cause a fire!
