20 Most Recent
Jeep 2004 Grand Cherokee Limited 4WD Questions & Answers
Running problems
That is usually a relay heating up and expanding little circuit board solder connections, so I would look at techs mentioning (blogging online) "resoldering" 2005 Grand Cherokee modules and relays, or the words defective relay and your year and model to see what the most common reports and repairs are. Mechanical issues are more sound, feel and heat indicated, running problems are demand, sound, feel and heat indicated (related), your problem appears electrical.
Whats the turn signal indicator light mean
If its constantly on turn your headlights on and check the side the indicator is pointing as in if its left side indicator check left side and so on for lights out my dodge ram did the same thing ended up being a parking light but it could be a tail light I'd check brake lights to just to make sure if its a parking light check the bulb 1st if its OK then its probably a ground or power issue if u need further assistance let me know
Cam shaft timing marks
the cam shaft timing marks should line up this is the process to doing a tune up . if you do not have the proper tools or knowledge, they will not line up , get a professional to do this , if you knock out your timing your car will not run, and then that would be the beginning of your troubles.
Getting only cold air when heat is on why?
I think your heater core is shot in your jeep,it's a bit of a pain to replace,but before you replace it check the thermostat first,maybe it doesn't have one or it's rusted and no good,for what it's worth I would replace it every year any ways.
