No.1 is it getting power, if it is then check if compressor is running if it is then gas could be the problem, if not running then it could be a board. If it is under 2 years old it will be covered by warranty, contact http://www.nostalgiaelectrics.com/
Have you tried it on electric?
If the fridge is level, and the rear coils of the fridge are warm and the fridge does not cool, you will more then likely require a cooling unit. Arcticold refrigeration manufactures brand new replacement cooling units that are available throughout north america Visit ArctiCold Refrigeration We keep it cold
Check the condenser grille on the back is clean and warm to the touch. It should cool down towards the bottom and the drier cooler still. If it's cold, suspect short of refrigerant. If it's hot, move the fridge away from the wall to help it cool down.
Its defrost problem.When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over
ice will get collected on freezer ventilations and that will block the
air passing section from freezer to fridge, so the freezer gets cool but fridge
section does not cool.Try
manual defrost by unplugging the refrigerator from main power outlet
for 24 hours then reconnect it and check, if the same problem is noticed again,.
If yes then its defrost board problem. The defrost board located in the back of
fridge section. You can get required parts from www.repairclinic.com or from
online sears part site. ------------- Thank you.
Please check the Thermostat switch settings. Try to put it to max cool and then see the results.
If it still does not cool the you have to check the refrigent. It is lee and leaking somewhere.
Get a technician and get it charged up.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it. The ice may have also stopped up this opening blocking the air flow.Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
