20 Most Recent Nostalgia Electrics Kegerator Beer Fridge Questions & Answers
sounds like the thermostat. can you bypass it (ie connect the two wires together) and make it run all the time? If so, replace the thermostat
Nostalgia... | Answered on Apr 22, 2014
If the ambient temperature matches the temperature achieved through refrigeration, why would the refrigerator run? Is your beer cold?
Nostalgia... | Answered on Jan 25, 2014
You need a new start device if your compressor is not running/pumping.That is the box on the side of the compressor .If you can put your hand on the compressor to make sure it (compressor) is than you have a Freon leak. The small line copper coming off the compressor should be between 75 & approximately 85 if its not ho you have Freon leak somewhere.
Nostalgia... | Answered on Nov 15, 2013
Well the problem seems in the Water Inlet Switch, there are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit, component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Thanks
Nostalgia... | Answered on Aug 21, 2009
SADLY EVEN WE HAVE TO CALL A REPAIR SERVICE OCCASIONALLY SOME TESTING NEEDS DONE THAT WE HAVE NOT GOT THE EQUIPMENT TO DO
Refrigerators | Answered 2 hours ago
Umm. Ok. If you want to get rid of them you can raise the temperature of your freezer a degree or two
Refrigerators | Answered 11 hours ago
Nostalgia Electrics Kegerator Beer Fridge Logo
14 questions posted
Top Nostalgia Electrics Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Nostalgia Electrics Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Refrigerators
Most Popular Question
cooling issues
  • Refrigerators
