20 Most Recent
Nostalgia Electrics RRF325WHT 2-Door Retro Style Fridge/Freezer Questions & Answers
Not getting cold
No.1 is it getting power, if it is then check if compressor is running if it is then gas could be the problem, if not running then it could be a board. If it is under 2 years old it will be covered by warranty, contact http://www.nostalgiaelectrics.com/
12/2/2013 11:11:06 AM •
Nostalgia...
Answered
on Dec 02, 2013
I have an ice maker
Well the problem seems in the Water Inlet Switch, there are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit, component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Thanks
8/21/2009 6:23:23 PM •
Nostalgia...
Answered
on Aug 21, 2009
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
