Haier HWD1000 Logo
Felipe Claudio Posted on Nov 14, 2013
Haier error code uo4 - Haier HWD1000
1helpful
My Haier refrigerator model HSBS562iS has an error code 1 . Can you explain if there is a reset procedure and a fix for it please ?
Hi Brett,
When the Haier refrigerator shows an error code, try this before replacing any parts or taking the refrigerator apart...
- Power the Haier refrigerator OFF for 10 minutes, then power back ON. (Unplug the refrigerator for 10 minutes) -
The error code may disappear after a reset is completed.
- If after removing power to the refrigerator in an attempt to reset, the error code comes back,the freezer fan is bad and need to be replaced.
Here is a link to Haier Parts.
Also make sure there is No Recall on your particular model or serial.
Best of luck,
JP
https://www.haierappliances.com/parts
Haier air con duct type display error f9
Google Haier air conditioner error codes. Also check the code I see codes F0 through F4. F9 is not listed could it be a "4" instead of a "9"? F4 is the air flow sensor is off.
What does PSTD stand for on the remote?
Washing Machine ' FAQ ' Help & Troubleshootings ' Haier ZA
www.haier.com/za/help_and.../faq/washing_machine/
HaierQuestion : Error Code-control panel display "Err2" · Question : Error Code-control panel display "Err5" · Question : The door lock light flashes 8 times and stops .
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
11helpful
3answers
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
