20 Most Recent
Haier HLP21E Top Load Washer Questions & Answers
Haier HLP21E Top Load washer keeps beeping &
I have a Haier HLP21N that had the same problem. Three blinking lights and refused to spin. It turns out the issue was the lid. The left side plastic hinge had broken the week before. What I didn't realize is that when the lid closes, that back hinge pushes up a rod which tells the machine that the lid is closed and it's safe to spin. So check that hinge and if it is broken you will either need to order a new lid or find some material to stuff under the hinge so that it stays up. I chose the latter option. Just know that going the DIY route means that your machine will continue to spin if you open the lid going forward!
Haier not drying
Two possible causes. Try cleaning the fabric softener residue off of the temperature/moisture sensor. The other cause could be the thermostat has failed.
Where is the lint filter located on this washer?HLP21N
Hi.It may be that these machines dont actually have a lint filter,they are making alot of them without lint filters now days.There would be a button trap down at the side or the rear i would imagine for cleaning out debris such as coins,hair pins,Etc.
My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.EDIT: one of the mounting screws on the bottom of the tub will create a "tear" (or another word that rhymes with track) in the tub (Fixya says "The word $@#%^ is considered as profanity on Fixya. Please review your answer and try again"). I used a plastic soldering iron from Harbor Freight and cut a piece of the plastic webbing off the tub to "solder" the hole shut on the tub.
I have a haier hlp21n
I tried replacing the motor and this problem persisted to me. I spoke to a service technician who has encouraged me to replace the sequenser but I'm hesitant
I smell burning
the clutch is slipping. i have rebuilt them in the shop but it is faster and cheaper to buy a new one
Why will Haier HLP21E drain following wash cycle, but not drain following rinse cycle/before spin cycle?
Hello Michael;
My name is Peter. I am a retired field service appliance technician.
It sounds like your system just needs a good cleaning. Soap film will build up on the draining system components. You need to clean your float and insure it moves freely and makes contact with the float switch which turns on the pump. You may also need to disassemble your pump for cleaning.
There are products available for cleaning clothes washers, but these need to be used on a regular bases. I do not think they can clean enough to solve your current problem. Use after you have cleaned.
Can't find Haier lint filter for HLP21E
http://www.repairclinic.com/SSPartDetail.aspx?s=b198i1226155&PartID=1226155
My washer did not come with the Lint Filter. I contacted Haier Customer Service and sent them all the info they requested such as copy of receipt and etc. That was several weeks ago and Haier still says that they have yet to receive that letter. Or they say that due to high volume of warranty letters they receive, they have yet to process it. Anyways, I got fed up with the customer service or lack of, I started surfing the web for the lint filter and found the above site. The filter is very inexpensive and I got it in several days.
How to replace washer lid on haier model hlp21n
You can buy the lid at encompassparts use p/n:WD-4250-11but replacing it will be difficult. You have to remove the entire top but I have seen one replaced without going to all the trouble. It's hard to explain but you have to angle it a certain way and get the pins installed but if you don't want to risk breaking it, buy an aftermarket warranty from Sears and have them break it. For 80. dollars they will cover all the machine repairs for one year any problems.
