20 Most Recent Haier XQG50-11 Front Load Washer / Dryer Questions & Answers
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Haier XQG50-11... | Answered on Oct 08, 2018
Hi Cindy,
I think that you're going to have to remove the control panel and see if you can get to thebuttons from the back. Make sure that power is off.
http://nodevice.com/manual/haier
Haier XQG50-11... | Answered on Aug 06, 2015
it appears to be a control board problem
have a technician check it out.
Haier XQG50-11... | Answered on Jun 21, 2015
UNPLUG THE UNIT,WAIT 5 MINUTES THEN PLUG IT BACK...
WHAT HAPPPEN?
Haier XQG50-11... | Answered on Mar 29, 2014
probably a blocked pump. unplug and move washer out from wall. remove back panel to expose workings. pump is down the bottom, and you should be able to disconnect any water pipes and check inside pipes / pump for foreign objects.
Haier XQG50-11... | Answered on Nov 12, 2013
Unbalanced laundry distribution... According to the manual
Haier XQG50-11... | Answered on Jun 20, 2013
Replace the pressure switch on the unit. Part #W10339251 for a description on how to remove machine cover reply to this message.
Haier XQG50-11... | Answered on Jun 07, 2013
do u still need it
Haier XQG50-11... | Answered on Apr 24, 2013
Once you remove the rear access panel, you would see the main pulley on the rear of the outer tub. You need to remove that nut with a metric allen wrench. once the pulley is off, you can then remove the bolts holding the yoke in place. The Yoke and the bearings are available as a part assembly from haier. It is highly unlikely that you would need to replace the outer tub.
Haier XQG50-11... | Answered on Apr 23, 2013
I had this same problem. There are two possible solutions. First, you need to look underneath (use 2 people) and see if any hoses are kinked. If that is not the case then the machine is pulling in too much water during the dry cycle. I'm hooked up to a sink so I just turn the faucet down until the water is just a trickle. This works for me. If yours is attached to the wall you need to turn down the cold water tap. Its a pain in the ****, but I discovered no one can fix this machine, not even Haier's recommended service A&E. I always know more than the repairmen, very sad. Hope this helped you.
Haier XQG50-11 Front Load Washer / Dryer Logo
85 questions posted
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Washing Machines
Most Popular Question
get error message 13 clothes not drying
  • Washing Machines
