What wire kit should i get. I have two seperate subs and no wires. for anything. i need something fairly cheap
If the subs are different models or sizes don't install anything.
use the best subwoofer you have, if you use both you can have cancellation with uneven woofers or damage them. use a large ported box and tune it close to the music you listen to.
use a minimum of 4 gauge copper or cca wire. anything smaller and you risk burning the wire, the brand doesn't matter. use 14 gauge or larger for speaker wire and setup your impedance of your subwoofers in the pattern that will give you more power.
see here.
http://www.the12volt.com/caraudio/boxcalcs.asp
SOURCE: WIRING A DUAL VOICE COIL SUB.
Just wire one voice coil each into left and right rear respectively, in series with the original rears or if this is too quiet, wire both voice coils in parallel together and connect as per original single coil unit.
As they are 4ohms each they can simply be connected as simple speakers on each rear channel output, since thats exactly what they are, capacitors are used inside to make them react to bass frequencies only. Wiring them up is no different to wiring up a pair of 6x9's.
Testimonial: "HELLO PLANET-X,I CANT BELIEVE I DIDN"T THINK OF IT IN THOSE TERMS.THANKS FOR YOUR HELP AND INSIGHT,GREAT EXPLANATION,YOU SHOULD HAVE BEEN A TEACHER."
SOURCE: I own a mtx 1501d.Also own a 18
THE AMPLIFIER NEEDS A 1 OHM LOAD AND YOU HAVE THE RIGHT SPEAKER TO PROVIDE THIS LOAD. THE AMPLIFIERS TERMINAL STRIP PROVIDES YOU WITH 2 POSITIVES AND 2 NEGATIVES, BUT THEY ARE ONLY FOR CONVENIENCE WHEN WIRING 2 DRIVERS. ACTUALLY THE 2 POSITIVES ARE THE SAME CONNECTION INTERNALLY ON THE BOARD, AS WELL AS THE 2 NEGATIVES. THAT BEING SAID, THE SIMPLEST WAY TO CONNECT YOUR SPEAKER IS TO PARALLEL THE VOICECOILS IN THE BOX BY CONNECTING THE 2 POS. TOGETHER AND THE 2 NEG. TOGETHER THEN RUN THAT POS. AND NEG. OUT OF THE BOX AND SIMPLY CHOOSE EITHER OF THE 2 POS AND NEG. OF YOUR CHOICE AT THE AMP. IF YOU EVER HAVE TO ADD A SUB, THEN YOU WILL HAVE 2 MORE TERMINAL LEFT OVER ON THE AMP. TO CONNECT IT TO AT THAT TIME. BY ALL MEANS, IF YOU WOULD LIKE TO RUN EACH COIL SEPARATELY OUT OF THE BOX AND CONNECT THEM TO ALL 4 TERMINALS, THEN THIS IS FINE TOO, AS EITHER WAY, THERE WILL BE NO DIFFERENCE WHATSOEVER. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE....V
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
