Amana PTH123B25AJ Heat Pump Air Conditioner Logo
Posted on Nov 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have PTH093B35AM amana PTAC. Heat is not coming on. Keeps blowing air.
Heat wont come on. Keeps blowing regular air.
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on Nov 20, 2013
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
229868
Points
3082
Check that the reversing valve is working and wired properly
3 Related Answers
Anonymous
  • Posted on Jan 31, 2010
SOURCE: looking for manuel reset on heater amana ptac
I have a Amana PTAC Model PTH153A50AC with the DigiSmart upgrade kit (DSUK01B) which as of last night stoped generating heat. I tried the Diagnostic and got a "LF" displayed. But I find no reference to what LF means. HELP please. Also I looked but can't find a reset button either.
Signed
House without heat
oscarn
Oscar Netto
  • 110 Answers
  • Posted on Sep 07, 2007
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Anonymous
  • 6 Answers
  • Posted on Sep 09, 2008
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
1helpful
Amana Wall unit blows cold air before heating
The cold that you describe may be just unconditioned air? If you are certain you can hear the comp operating for a couple of minutes, and then the heat starts, I would guess it is a reversing valve issue if it's a heat pump and it probably is. Or the control board acting up. I've had a lot of issues with the boards in the Amanda PTAC units. I can't remember how to configure it, but if you Google "Amanda ptac configuration", there is a lot of info online. May try a reset method first. Hope this helps!
1helpful
My Amana PTAC set to 90* blows cold air then warm then back to cold. The temperature outside is just a few degrees
sounds like the auxillary heat strips are coming on and off....what kind of time does it cycle on and off?
I have an Amana packed unit...blows cold air when on heat but if i turn temp to 90 then heat will come out but not at 72 or that range.
you probably have a packaged unit with a line voltage thermostat which is out of calibration...not an unusual situation. other than replace the stat, why not just use it by just setting where you need to - to get the results you desire? use a regular thermometer placed where you want to control to help you adjust properly.
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
3helpful
Ptac not heating
the board or the heater need to be replaced
2answers
2helpful
3answers
Ptac fan keeps blowing
Reset the unit to factory setting by take the master switch off of 10 sec.
Then press and hold the cool and heat button down while turning the master switch back on.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
