20 Most Recent Amana PTH093B35AM Thru-Wall/Window Air Conditioner Questions & Answers
you must read your instr. manual how to reset to default setting
go to www. fitness.manualsonline.com
God bless you
Amana... | Answered on Oct 09, 2012
If this is the serial number, it is a 1993 model.
Shastalaker7
A/C, & Heating Contractor
Amana... | Answered on Apr 10, 2011
Fixed in the middle of evaporator coil.
Amana... | Answered on Jan 04, 2011
see if you can find a new board the power failure fried it
Amana... | Answered on Jun 19, 2010
Press and hold up and down arrow at same time -press off twice to get into program mode (should read C1) -press heat button to scroll to C2 the use up arrow to scroll through options. You want to set it to read-out "On" then press off to set. This should be the continuous fan mode.
Amana... | Answered on Jun 15, 2010
There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
Amana Heating &... | Answered on Jun 10, 2019
Check voltage in , there could be one side of breaker burned causing only one side to come through. This happens on older main breakers frequently which messes up whole house.
How are you determining that one section.is cold and one warm? If this is in fact the case you have a blockage in the coil or a compressor that is down provided this is a multi compressor unit.
Amana Heating &... | Answered on Feb 06, 2019
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
Amana Heating &... | Answered on Jan 27, 2019
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Amana Heating &... | Answered on Jan 20, 2019
Amana PTH093B35AM Thru-Wall/Window Air Conditioner Logo
12 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
any one remember program amana
  • Heating & Cooling
