Just need to know how to get speakers connected to emachine. the old ones connected to monitor and cpu; but only see connection at cpu.
SOURCE: sound card for emachines w3653
go to your sound card preffersants and change it to your set up .
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Cant connect to internet with emachine through lynksys router.
you will have to add an ethernet card to your emachine if it will take one, or you might be out of luck
SOURCE: Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
SOURCE: Black screen on my desktop, and connect pins are broken & bent
You'll get either no signal or missing color(s) if pins are bent or missing.
Carefully bend pins back with small needle-nose pliers. Pin 9 is missing by default - if any other pins are missing or broken, you'll need an expert to wire a new VGA plug.
SOURCE: W6409 eMachines Desktop Wireless Adapter issue.
Check out the emachines site. Just check the model number and all drivers will be on there.
Hope this helps
