Samsung Model HL-R5067W will shut down intermittently and when restarted will come on and sometimes after a few minutes shut down again. Othe times when restarted it will run without a problem for several days.
I just called 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
My total was 167.08 for Fl. You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
OTHERWISE- THIS SET MAY HAVE THE DREADED 1500UF POWER CAPACITOR ISSUE WHICH ARE EASY TO SEE IF YOU CAN ACCESS THE MAIN POWER PC AND VISUALLY CHECK FOR 'POPPED' CAPACITORS ON THAT PC. JOE TV
My samsung projection tv made a noise and screen went black. what is wrong?
BUY NEW ONE...hehehehehhe ^_^
Dido, same problem, wish we could find out why!
I have the same problem and Samsung support told me that the lamp needs to be replaced.
Tv will not come on . It sounds like it is powering up but the screen stays black. Power button says Timer Lamp
Standby/ Temp
Tv makes a clicking noise, like when it is turned off & on.
same problem as otherwise...what is the answer???
I have the Samsung HCP 4353 WX/XAC and had the projection lamp replaced to correct a color and focus problem, and ever since has the problem of having to reset the TV by pulling the power plug from the wall, sometimes several times during a movie making this a real nusance if you have a fix to this problem please email me at [email protected]
tv will not come on
it used to shut down occassionally
not it wont power up at all
