FOLLOW this steps and fix it. God bless you
Fully charge the Sony digital Handycam. If the camera is
not powering on or shutting down during the middle of a shoot, it is due to the
battery. If the battery is unable to hold a charge (this occurs after a few
years of use) you must replace the lithium-ion batter.
Press the "Menu" button if no audio is recording
on the video camera. Choose the "Record" feature, then select
"Audio." Oftentimes the audio comes (or is accidentally turned) off. Select
the "On" option and exit out of the menu. Now all future recordings
capture audio in addition to video.
· 3
Delete unwanted video files if your hard drive is full. When
the internal hard drive is full you receive an error message stating the
camcorder is unable to capture more footage. Bring up the "View"
option on the camera, then select a video file you no longer want and choose
"Delete."
Turn off the video camera and remove the battery. Wait a
few minutes before inserting the battery back into the camera. If the menu or
any other internal hardware on the computer is malfunctioning performing this
reset corrects the problem.
5
Upload the video content from your camera to a computer
via FireWire cable instead of USB. When using USB the quality is downgraded as
it is unable to support the higher data stream required to upload videos. If
you don't have a FireWire port on the computer (it is similar in size to a USB
connection, but one size is curved and a "Y" icon is printed next to
it) you will have to use the USB connection.
SOURCE: my video camera is lock 'cause i select VCR OFF from menu
YOU WILL CONTACT TO NEARER MECHANIC IT IS TECHNICAL PROBLEM
SOURCE: problem in video recordeing from tv to camera
IT may not like that you are taking a feed from the tv to you camcorder?
IT may be detecting some form or copyright and is attempting to block the recording.
IF the end result is that you have a good recording then you should be ok. But dont take my word for it contact Panasonic corporate to see what they think.
Cheers
Al
SOURCE: I cannot remove the x1 auto-hss display that is
The manual says to press Display and Pause/Still at the same time.
