20 Most Recent Panasonic AG-DVX100A Mini DV Digital Camcorder Questions & Answers
How to you fix reel lock problem
My Panasonic ag dvd100be modal , auto off t-reel lock earr please solve my problem sir.
12/19/2018 4:27:16 PM • Panasonic... • Answered on Dec 19, 2018
My dvx is old, and just recently the picture
If it's that old, I should take the 'A' train to the nearest dealer and treat yourself to a new one - things do wear out, you know.
6/19/2017 8:37:48 PM • Panasonic... • Answered on Jun 19, 2017
5answers
Warning message
PSD NG is an error dealing with the OIS [optical image stabilization]. It can be fixed, it is not as terminal an error as many have rumored it to be. The caps could be a cause, but very remotely THE cause. You can have the camera sent in to Pani, and they will fix it, and you will get a bill for $300 - $600.
However the main cause for so many of the dvx100 series to have the psd ng error is loose cables. If you feel sure of your self with a screwdriver, tweezers, & forceps, you can make the repair yourself. In simple terms, all you need to do is reseat the ribbon cables. Follow the steps & photos here:
http://www.dvxuser.com/V6/showthread.php?t=172290
I did this repair with great success. It was a nerve wracking two hours, but I have not had the error reappear since. I got the camera from someone dirt cheap, [read 1/4 value], because of the psd ng error. I made the repair & not only have a fully operational unit with beautiful pictures, but I also quadrupled the value of it.
6/15/2015 4:52:09 PM • Panasonic... • Answered on Jun 15, 2015
"where can I purchase a Panasonic DVX 100 camera mains power adaptor
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0&_nkw=+Panasonic+DVX+100+camera+mains+power+adaptor&_sacat=0&_from=R40 i hope this helps you .
2/17/2014 8:47:31 PM • Panasonic... • Answered on Feb 17, 2014
0answers
Service manual
Be the first to answer 1/11/2014 5:04:38 AM • Panasonic... • Posted on Jan 11, 2014Be the first to answer
3answers
Showing warning psd ng in dvx102 panasonic video cam
PSD NG means that there is a problem with your electronic image stabilization system.I think Panasonic got stuck with a bad batch of gyros. Take it back if you can, otherwise use lower resolution or hold very still when filming.
8/8/2011 10:22:00 AM • Panasonic... • Answered on Aug 08, 2011
It is a warning psd ng what is that?
warning psd ng solution
3/12/2011 10:07:55 AM • Panasonic... • Answered on Mar 12, 2011
It makes a clicking sound
This is normal. The sound is the auto-focus coil moving back and forth. When the camera is powered up, the coil will be energized and will not make the noise.
2/2/2011 11:33:13 AM • Panasonic... • Answered on Feb 02, 2011
Camera is cycling through color
Hi.
If the problem happens on all pre-sets, and if it happens all the time, and if the color is shadow-like then the problem is not the digital board trying to balance whites or color, or a progressive scan related problem, but a defective digital imaging sensor (a CMOS sensor in this case, not a CCD like in compact cameras).
If you get weird and incorrect color, and shadow like motion blur, then the sensor that captures light must be replaced. The sensor is located inside the camcorder body right behind the lens.
You can get a quote on repair calling Panasonic at the number listed in manual or in your local Panasonic support website. You can get a quote from a third party service here:Repair.
Regards.
Ginko.
12/6/2010 1:34:35 PM • Panasonic... • Answered on Dec 06, 2010
My video cam shows warning
http://www.digital-camera-battery-charger.co.uk
http://www.battery-charger.us
We are committed to the laptop battery, digital camera batteries, camcorder batteries, PDA batteries and Chargers, development, production and marketing services, the products sell well not only 11 years in Europe, America, Korea, Taiwan, Hong Kong and Southeast Asia and other countries and regions, but also through all major cities across the country to establish a sales agent in the form, the establishment of a comprehensive sales network and after-sale service system, the first class products and perfect after-sales service to consumers.
11/5/2010 8:42:20 AM • Panasonic... • Answered on Nov 05, 2010
2answers
Panasonic dvx1000a has no audio input, for xlr
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
9/12/2010 5:41:44 AM • Panasonic... • Answered on Sep 12, 2010
2answers
PSD NG
Hello! You need to disassmble the side which includes the lcd monitor, so you can see the lens and ccd block area. Blow air inside to clean the parts,and reassemble it .If the problem continues please let me know.There's another way then.
7/3/2010 6:27:34 AM • Panasonic... • Answered on Jul 03, 2010
Can not get video siganal from dv output
Remember in UK we are on Pal not NTSC ok?
5/26/2010 10:16:39 AM • Panasonic... • Answered on May 26, 2010
Main Power lost for Panasonic AG-DVX100A Digital Video Camera
hello!
send a mail to me and i'll send the schematic
[email protected]
2/26/2010 2:09:48 PM • Panasonic... • Answered on Feb 26, 2010
DVX100A panasonic camera tape mechanism not working
You can open the cassette cover and spray inside the upper left side of mechanism(closer to the back) with contact cleaner spray,because there is a rec inhibit switch.If it's not damaged and just dirty you solve your problem ,but if is damaged it needs replacement.
2/2/2010 7:22:44 PM • Panasonic... • Answered on Feb 02, 2010
Tapes won't Playback in other deivice
Hello! If the recorded tapes playback ok on the camera and not ok on another devices, you need to readjust the playback on this camera using a tape which playbacks fine on the other devices. This means that is a small difference on the tape transport. So when the supply and takeup post rollers readjusted and the audio and video playback are good, then your camera is fine.
2/2/2010 7:16:49 PM • Panasonic... • Answered on Feb 02, 2010
Lens hood broken off and I need replace ment part to screw it bac
you can email me a picture of the broken part and i will send you the part numbers of the broken parts here: [email protected]
2/2/2010 6:55:00 PM • Panasonic... • Answered on Feb 02, 2010
See audio levels but don't hear
ADJUST THE AUDIO OUT LEVEL WITH THE AUDIO MON/VAR ON TOP OF CAMERA
1/22/2010 7:06:17 PM • Panasonic... • Answered on Jan 22, 2010
Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
46 questions posted
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
AG Panasonic
  • AG Panasonic
Most Popular Question
warning psd ng
  • Video Cameras
