SanDisk Sansa E280 MP3 Player Logo
Posted on Oct 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E280 and my computer do not connect
I have a Sansa base station. Yesterday, when inserting the E280 to the base station, the thumbwheel blue light turned on and I could not bring up any of the functions. The screen was black and there was no display. The blue light was on all night and the battery charge ran out. I reinserted the E280 to the base station and the functions returned except that the video and photo memory were erased. All the downloaded music and fm station set up were accessible. I then tried to connect to the computer's USB port. However, although there was an indication that it was charging, there was no communication between the E280 and my computer. I changed the USB mode to MSC then to MTP but to avail. It seems that the E280 was reset and the factory settings seem to have been erased. What should I do? My E280 is two weeks old.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on May 26, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2175311
Points
14133
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Won't Find Sansa e280, will charge but won't connect
no.sometimes any problems with the chip set.the butter way is to go to a servicing center
My sansa e280 will not play on the docking station or computer.
Two problems:
1) Your Sansa (and just about any other mp3 player) will not play while it is connected to the computer - it is only supposed to play once it is disconnected from the computer
2) Your docking station might be for brand-name iPod's only - using an incompatible docking station is one possible way to ruin your player
Get a simpler external speaker system with an audio jack that runs from the headphone jack of Sansa to the input jack of the docking station.
-Tha Mp3 doctor
Sansa E280 does not play ont its craddle
Get a compatible docking station, or a simpler external speaker system.
2answers
Sansa e280 wont turn on
What i do is drop it not hard but a light drop and it should turn on than
2answers
Micro sd card
Does your computer has an internal card reader?
1helpful
E280 not charging
You might have to get a new charger--But be careful. If the charger isn't made especially for the Sansa e280 there's the possibility of it messing up the mp3 player itself.
It could also be your computer's USB port. Try using a friend's computer or a different USB port perhaps and see if it works then.
2answers
Help!!!!!!!!!!!!
Get at firmware upgrade for the device..usually that will solve the kind of problems you are having...
3answers
Device frozen
there is no know solution for this problem.. aparently its called error is called "blue light" and yeah.. according to customer service and forums the sansa is toast when this occurs...
Sansa e280
Cannot correct - sorry
PC won't detect sansa e280 please help me
I had the same prob with my e280 yesterday and i bought it 4 days ago. I'm using a vista o.s. and i found a way to transfer files this morning. if you are using a vista os you should first set your sansa to MTP mode so that your windows media player can detect your e280 then you can start synching. If you are using XP o.s. there shouldn't be any prob with that but you have to switch to MSC mode. you can find these settings on the setting menu of your e280 then USB mode.you can also open the E280 player if you see it on "my computer" there you can transfer the files.don't use your wmp player when you are doing this on vista cuz the wmp player will also synch at the same time and it will synch the same file.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
