Engine stalls at anytime after the initial warm up(the water temp gauge at normal),when restarting the engine sputters and surges and most of the time re-stalls with a slight backfire..after about (2)minutes, the restart is fine and away I can drive..the frustrating problem is that the engine will stall in traffic or at a stop and recently has even stalled when cruising the highway at 60..recently replaced filters,plugs,wires and flushed the cooling system with no solution..the engine is a 3800 buick v-6 in a 1990 Reatta..246k miles with no overhaul..any suggestions for my mechanic?
Per your description, I would suspect a fuel pump issue. When the fuel pump is running the pump impeller heats up. On an older pump the impeller can begin to seize up and momentarily stops and starts. Some times it just stops and has to cool down for a couple of minutes, then is ok for a while.
To test this theory, when the engine stalls and stops, your mechanic can use a rubber mallet and hit the bottom of the gas tank, this will free the pump impeller and the car will start again.
Or, have him install a fuel pressure gauge and go for a drive. If the pressure begins to fluctuate and drop, you know the pump is causing the issue.
Good luck, let me know.
Regards,
