HP Pavilion a1600n (882780776265) PC Desktop Logo
M
Margaret Raub Posted on Oct 31, 2013
How to turn wifi on and off? - HP Pavilion a1600n (882780776265) PC Desktop
Maher Kareem
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Oct 31, 2013
Maher Kareem
Contributor
Level 1:
Welcome Back:
Answers
10
Questions
Helped
2652
Points
17
If you using windows 7 or less check in start bar near by the clock
Can't connect to WIFI
I might need more information from you like phone make/model, os, etc. but the best place to start is to turn off wifi locator, turn on airplane mode, turn phone off, turn back on, turn airplane mode off, turn wifi locator back on and search for wifi signal
May 04, 2016 • Cell Phones
I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ‎23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ... Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
How to turn WIFI back on on Toshiba Satellite C675-S7200 Laptop
May be a faulty wifi card.
But check Adapter settings in control panel to ensure wifi card is "enabled" and check device manager to ensure correct wifi driver is installed.
I have no wifi so will i connect with wifi on my mobile
you are not required to have wifi at your home or anywhere else, there are wifi hotspots such as Mcdonalds and other places. If the data on her phone is turned on you can pick up the wifi on your phone which may cause you to have data charges on your bill. You should be able to turn your wifi off so that this does not happen you may also be able to turn off your data under your setting>cellular>cellular data and then you will not be able to connect to any data at all. Hope this helps
My acoustic energy wifi radio does not link with any wifi service. Any ideas?
hope u have turned on wifi device as shown to all..
let check wether wifi device has no tech issues
I have a samsung galaxy gt-i9000 but my wifi nolonger works when i turn it on it says unable to scan twice then turns itself off.
Hello there,
You will need to be sure that there is wifi turned on in the area that you are trying to use your phone.
Then you try to go through the wifi list on the phone and delete all the wifi that it has ever seen and worked with. Then you turn off the phone for about 5 minutes, then you turn it on and turn on the wifi on the phone and search for the wifi available, that way it will search for the available wifi and connect to it.
Thank you for using fixya Caseytech
No wifi...how to connect to wifi
router (turn off at least wait in seconds) turn it on again your router... but be sure your router connect in your modem... and if you see a wifi sign lights... just turn in on your laptop wifi ... press FN and F8 wifi on...
thank you...
1helpful
WiFi radio is turned off
The EZ button software must be installed to turn the radio on or off. The switch on the side does nothing.
HOW TO TURN THE WIFI ON THE ARCHOS 605 160GB
you need to buy the wifi plug in from the archos website, then unload it on to device
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
