I have a silver leader 4 mobility scooter with a dynamic ds 100 unit under the rear end the status light is flashing 7 times which from what i have been able to find out is the wig wag potentiometre have...
hi,
ok so 7 flashes is a speed pot related error, you need to make sure that the speed pot is in the central position , look under the stem and you should see a cross head , now that should be straight not at slight angle, without you touching the throttle lever , if you have a meter disconnect the pot and take a resistance reading, it should show about 2.5K - using the centre tap , if it is a 5K pot fitted , in fact for that controller it should be a 5K pot , please check the terminal connections on the controller, good fitting and clean.
Take leave feedback.
Regards
GeWiz.
