My Grill will no longer lift
I just had mine apart today because the cable broke. There is only one damper, in the left side where the pedal is. The other side is controlled by a cable that is strung on rollers. My cble broke so i had to replace it with one from a hardware store. I noticed that everything needs to be oiled for the system to work good. The gas strut/damper is inside of the lift tube. I would think it could be matched up with one from an automotive store. Autozone has a pretty good selection of them. But, The strut that is in the grill has a special end on it to fit the lift tube, you would have to somehow fabricate a new end or try to cut and weld or braze the old one onto the new strut. I have not had the strut problem yet because when I store the grill I leave it in the up position. this takes the stress and pressure off of the strut. Hope this helps.
