20 Most Recent
Nostalgia Electrics Hot Dog Grill Roller with Griddle Questions & Answers
I bought my son an
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
10/27/2011 1:22:35 PM •
Nostalgia...
Answered
on Oct 27, 2011
How long do you put hot dogs on the roller grill?
Once you have the rollers hot (10 min.) it should only take about ten minutes for the dogs to heat up... they are fully cooked so you anly have to get them hot, but you can let them on for a much longer time if you want too, like if you are selling them at a stand...
heatman101
4/29/2010 11:40:42 PM •
Nostalgia...
Answered
on Apr 29, 2010
How much oil do you put in with the chocolate?
Experiment with it. Start with just a little oil and periodically add more until it flows properly. Be sure it sets up when it gets cool, if it doesn't you have to much oil.
Good Luck,
Gilshultz
12/3/2009 3:26:50 AM •
Nostalgia...
Answered
on Dec 03, 2009
