20 Most Recent
Nostalgia Electrics KPM-508 Popcorn Maker Questions & Answers
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
11/4/2014 9:06:45 PM •
Nostalgia...
Answered
on Nov 04, 2014
Will not heat up
That is a thermostat. it should have continuity at room temp, and open at popcorn popping temps. There are no replacement parts for this manufacturer.
2/13/2014 7:52:33 PM •
Nostalgia...
Answered
on Feb 13, 2014
Wiring schematics
There are no wiring diagrams for this manufacturer.
General wiring practices are that the Hot wire(black) goes to the thermostats, and the neutral wire( White ) is attached to the heat element for the return.
Switches are on the Black wires to break the circuit before power reaches the item it is controlling. A white wire on a switch is for the return from the light in the switch.
11/19/2013 7:47:35 PM •
Nostalgia...
Answered
on Nov 19, 2013
Will not heat up and pop
Your power cord I would follow into the machine and hunt for a broken wire or a blown fuse possibly. Most pop corn makers are just about like a coffee pot. They have a klixon to control the temp and a couple of bullet fuses in line to prevent over heating. All of which is loacted on the base of the kettle. I wish I could be there to help ya get that popcorn popper working. Feetball season is nearly upon us.
Contact the makers If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
8/5/2012 6:34:55 PM •
Nostalgia...
Answered
on Aug 05, 2012
I purchase this popcorn model number ofp901 i have
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a
HOT AIR popper; oil
SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
3/25/2011 6:39:15 AM •
Nostalgia...
Answered
on Mar 25, 2011
