SOURCE: Transfer from Widescreen camcorder through S video results in Full Screen instead of Widescreen
have you set the dvd to widescreen? i know some change automatically when there is widescreen input but some need to be changed manually. This should be in system settings. hope this helps
SOURCE: DVD-S35 Panasonic - bandwidth information OSD
I have upgraded the firmware on my player and the problem disappeared. There is a "bitrate display" option in the Settings menu, but it didn't change anything when I tried it (before the upgrade). Now it isn't necessary.
SOURCE: I purchased a DVD that states: Widescreen Format
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Never mind. Figured it out on my own!
