20 Most Recent
Panasonic DMR-ES10 DVD Recorder Questions & Answers
Set 1
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
5/25/2023 11:12:44 PM •
Panasonic...
Answered
on May 25, 2023
U61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
5/30/2019 2:27:44 AM •
Panasonic...
Answered
on May 30, 2019
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
1/6/2018 3:07:20 AM •
Panasonic...
Answered
on Jan 06, 2018
When I first purchased the
If you take it apart an clean it with alcohol it might work. Many times it's the sticky stuff that shorts an clogs up the device. , try it to see cant lose.
6/7/2017 7:48:13 AM •
Panasonic...
Answered
on Jun 07, 2017
Lock message
Hi!
My DMR-ES10 appears since last month, the same message, and lets myself crazy!
Today, after a desperate try, pressing the buttons, I found the solution:
Simple press the POWER BUTTON and STOP BUTTON of the unit for a few seconds...
VOILá: The UNLOCK message appears in the display and the unit return to operate without the lock message !!!
For Lock again, press the same buttons at same way until appears the Lock message in the display.
This is an undocumented command...
I hope to help you!
1/13/2017 10:22:27 AM •
Panasonic...
Answered
on Jan 13, 2017
DMR-ES35V Cannot operate any functions ...
Just found the answer in another post, it works.
Hold down the "1" button and the "Enter" button together for about 10 seconds while pointing at the player. This seems to "reset" the remote and everything works fine.
4/23/2015 3:21:58 PM •
Panasonic...
Answered
on Apr 23, 2015
Is there self help repair on elictronics books
You know, that's a good question and one that I wanted answered with this recorder's many problems. But there is not one, I'm afraid. I just kept researching on the net until I found enough solutions to figure out repairs. However, I have one that is still running strong after 4 years (with minor tweaks) and one I just had to chuck. Post your problem and you may find a solution. If it's electronical rather than User, you might be out of luck and better off looking at newer brands. If it is just a User hiccup, most are pretty easy to figure out, especially after someone tells you what it is !!! Good Luck.
11/7/2014 8:47:56 PM •
Panasonic...
Answered
on Nov 07, 2014
