Compaq AlphaServer DS10 Logo
A
Anonymous Posted on Oct 16, 2013
Pinout power supply - Compaq AlphaServer DS10
1helpful
Laptop compaq hp 6910 power supply pinout
laptops
that is an HP secret.
ask them at HP.com
its external power pack ac to dc.
most are 19vdc.
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
614-0037 pinout
I don't know that anyone has ever done a pinout of that custom vintage Apple Quadra/PM power supply. You may have to be the first! Let us know how it goes.
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
1helpful
Power supply pinout for IBM PC
check these 2 atx power supply connector image.
click here
click here
Need the schematic to plug in the power connectors
This link http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
is a great page for the standard ATX pinout and related info.
WARNNING dell's and some other psu's have a different layout.
If you look onto the power supply box, you will see a modle like
ATX130p3, google this with "pinout".
1helpful
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
