20 Most Recent
HP Compaq Evo w4000 PC Desktop Questions & Answers
I forgeten password
You can reset the bios password by shunting the appropriate wires on the motherboard or you can remove the battery for a few hours. You can find out which wires from the manual which you can download. Make sure the manual is for the motherboard that is in your computer. Sometimes the same model of computer will not necessarily have the same motherboard, so you have to go by the number on the motherboard rather than the case.
If the password is for windows or some other software rather than the bios then this won't work. I recommend that you do not set a password for the bios unless this will be a public computer.
Everything wont open only safe
If your operating system is windows then it is unstable.
can you manage to do restore point recovery and choose an ealier date?
try opening the computer not only from safe mode but also using minimal
drivers, domain controllers only. (most computer press F8 when starting)
If everything fails you have to reformat and re install everything.
make sure your work is saved well somewhere else
before attempting repair.
I have faced a problem on Compaq Evo W4000 that
Give a try to update BIOS.
Click here and follow the intrsuction
- Obtain a formatted 1.44-MB diskette and place it in your A: drive.
- Download the SoftPaq to a directory on your hard drive.
The file that is downloaded is an executable with a filename based on
the SoftPaq Number above.
- From that drive and directory, execute the downloaded file and follow the on-screen instructions to build the ROMPaq diskette.
- Place the newly created diskette in the A: drive of the
computer to be upgraded or restored and cycle system power to boot from
- Follow the on-screen instructions to select the Compaq System ROM and flash the firmware.
WARNING: DO NOT TURN OFF POWER OR ATTEMPT TO REBOOT THE COMPUTER DURING THE UPGRADE PROCESS!!!
My computer boot very well
try installing the OS again. it should work for you well. And if still you have the same problem, then install the LCD monitor software if you have a LCD monitor.
Thanks for rating
good luck
The power supply unit of
This power supply is quote HP, "250 W Power Supply (PFC)". Almost any power supply will provide that much power. The problem is in a mini tower, the shape has to be matched and that limits you generally to the manufactures PS. Here is one that will replace yours.http://www.codemicro.com/store/product/243891002/New
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Wen i shut down the
shut it down thru the start menu.....or hold down the off on switch longer than 3 sec.
No power up
it probably will be because of your power supply if you bring it to a store like bestbuy they can change it for you.
Compaq EVO W4000 257951-002 motherboard
Under the cover that you lift off to see the motherboard. Otherwise, go to HP.com and type your model in - you can get all the documentation from them, for free.
Purchasing RAM
I believe it's pc133 sdram for the evo w4000 shown above. You can either try going through the manufacturer's website or just some google searches to see the computer's specs.
Server 2000
Hey karl12, i think some more info would be helpful. Any big event that made this start. Have you tried running memtest 86? If you have multiple sticks of RAM try each one. Is there any beeping during boot up? Have you tried using a windows disc to boot to a repair console? Also what are your bios settings? Have you tried changing to load safe defaults in your bios? Is your bios recognizing your boot hard drive? These should help limit the possibilities.
