20 Most Recent Compaq AlphaServer DS10 Questions & Answers
the Only VMS post on fixya ever.
wow. from the dark ages of DEC. VMS. OS.
sounds like bad drive if it can not be mounted.(or disk bad)
sounds like you are 42 years behind the upgrade curve too...
i used to work on all DEC systems. so know that . 1975
the DS10, is now 18 years old.
here is a relic manual, on that
http://zzz.physics.umn.edu/_media/computing/department/ds10-cr.pdf
is this your only DS10, of not try the drive on system #2?
ahh its now called OPENVMS,, amazing thing that is.
open vms was ported to ALph chips. 1992
then 2001 port of OpenVMS to the Intel Itanium architecture
so it's an 17 year old OS.
get HP proliant Server G7 up. and win. for sure.
Compaq... | Answered on Dec 13, 2017
HP Open VMS, HP Tru64 Unix, Linux, MS Windows
Compaq... | Answered on Jan 06, 2015
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
Compaq... | Answered on Apr 14, 2014
Enter the BIOS and select the cd drive as the first boot device.
Compaq... | Answered on Apr 29, 2013
I am not very familiar with Alpha. Do either of these manuals help? Here is a Console Reference and a Console Firmware guide that talks about it.
Thanks
Compaq... | Answered on Aug 05, 2012
check the computer memory Ram and the processor
The answer is to get hold of a high-speed case fan. I used a Scythe s-flex 80mm which has a +/- 5% RPM of 2800. rearrange the pins or use a choc-block such that yellow -> black, red -> yellow, black -> red. Hey presto.
Works for me.
Compaq... | Answered on Jul 04, 2010
just take the old battery to any shop, like Radio Shack, it is a common 3.6V Flat cell, they are pretty common, often used in car remotes etc, as long as it is the same voltage and size you can use any brand.
Compaq... | Answered on Feb 23, 2010
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may bshort..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
the Software part:..
1)hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(un check on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Compaq... | Answered on Nov 16, 2009
You need to have a bootable disc with the OS boot from it and install.
Compaq... | Answered on Jul 07, 2009
Version 7.1-2 is an older version of the OS. I will have to check, but I think that V7.2 will resolve this. What version of TCP/IP are you using? Back in the day when I supported TCP and VMS, there were some timing issues that causes odd behavior. If you can provide the details about your configuration, I can check and get back to you. If necessary, an examination of a forced crashdump may be needed.
A rare opportunity to work with VMS again!!
Good stuff.
Dan
Compaq... | Answered on Aug 08, 2008
This might help your quest:
http://64.223.189.234/node/891
Compaq... | Answered on Jul 02, 2008
You can get all the hardware that is supported on both HP's Site and the OpenVMS.org site. http://h71000.www7.hp.com/servermatrix.html
and
http://www.openvms.org/pages.php?page=OpenSource
HP has a hobyist section here: http://www.openvmshobbyist.com/news.php
If you just want to see what OpenVMS looks like and play with it in an emulator.
Compaq... | Answered on Apr 24, 2008
Hello Narvaar
I believe I've found what you need.
HERE is the OpenVMS home page
HERE is the support page for all the HP OpenVMS versions through 7.x & OpenVMS VAX 7.x
HERE is the support page for OpenVMS 7.x including manuals.
HERE is HP/Compaq's customer support contact information. If the info. and downloads aren't available on the site, customer support should be able to help you.
HERE is their "Questions Before You Buy" contact information.
Please, let me know if you have any difficulty accessing any of these sites or if you have any more questions at all, comments, etc. We're here to help.
Thank you,
BJ @:)
Compaq... | Answered on Apr 16, 2008
for any new hard disk first you have to create a partition table. Usually this is done when installing the OS. eg: for win98 you have to first create the partition in dos, format it, then run win98 setup. Now in WinXP this can be done when installing the OS. Similarly you may have to create the partition before runing UNIX setup. I Dont know the installation for UNIX. Usually the hard disk manufacturer supplies with some utility to do the partition. Like Disk Manager from Seagate.
Compaq... | Answered on Jan 03, 2008
Compaq AlphaServer DS10 Logo
28 questions posted
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
AlphaServer Compaq
  • AlphaServer Compaq
Most Popular Question
need cmos battery number
  • Computers & Internet
