SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
SOURCE: my nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
Please run the software calibration that coming with your equipment, see the instructin under the Hood motor, and follow the steps. or user manuals.This will guide your for diagnose and troubleshooting.
See the attached block diagram for troubleshooting and diagnose that I did prepare for customers.sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
SOURCE: Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
