I've a Zebra LP2824 printer , It gives me the Green-Red error .. And the manual guide told me that's a problem with flash programming .. What can I do to solve it ??
I would re-calibrate the printer and see if that helps, usually the quickest and correct means to fix ya !
Calibrate Zebra Desktop Printer
SOURCE: Zebra LP 2824
the error you are getting is a label size error. a label variance of as little as 1/203th of an inch can cause this.
you need to recalibrate the printer to the media, hold feed when powering up the printer letting go once the light flashes 4 times. this will force the printer to autodetect the label size.
if you are specifying the label size in you software or driver settings, measure and double check the label size
SOURCE: light is red and not green
There may be several causes to this problem.
1/ The lid of the printer needs to be firmly shut before the Red light changes to Green.
2/ If the ribbon has come to the end then the red light will come on, change the ribbon.
3/ If you have changed label size and not recalibrated the printer to the label then the RED will come on.
Any error within the printer will bring the RED light on.
You can download the 2844 User Manual from
http://www.lancerlabels.co.uk/2844user.pdf
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
SOURCE: I have a Zebra GK420t Alternately Flashing Red and
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
