Honda Maxus Pressure Washer MX5222 Logo
Anonymous Posted on Apr 20, 2009
Pull cord is loose on my Honda 2500 Pressure Washer unable to start engine.
  • Anonymous May 11, 2010
    you need to take pull start assy off check inside centre screw may be loose or needs re tensioning rope.return spring may be broken.
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on May 30, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
25617
Points
98
Complete pull rope units are available for appx $23
  • Anonymous Aug 20, 2012
    Do you have a source for the assembly; I can't seem to find it on line
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Honda XR 2600 pressure washer, cord will not pull on engine
This is typically due to the unloader bypass valve not operating properly. You can remove and clean this valve or you may want to replace the valve with a new one.
If you take the high pressure hose off of the pump and with the water turned on you can start the engine each time then you probably should replace the unloader bypass valve.
Here is a link to the pump.
http://www.allpartsinc.com/mmAllParts/Others/A14292-001.pdf
Have an Excell 2500, VR2522...... Pull cord broke and now i think the spring is broke; where can I get a new spring and directions to reassemble the pull start?
That pressure washer uses a Honda 5.5 hp overhead cam engine
You need to get the model number of the Honda Engine and then Click Here to go to the ereplacementparts.com website and put the engine model number to order the parts.
Jun 23, 2011 • Garden
3helpful
2answers
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
23helpful
2answers
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
2answers
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
