20 Most Recent
Honda Maxus Pressure Washer MX5222 Questions & Answers
Honda XR 2600 pressure washer, cord will not pull on engine
This is typically due to the unloader bypass valve not operating properly. You can remove and clean this valve or you may want to replace the valve with a new one.If you take the high pressure hose off of the pump and with the water turned on you can start the engine each time then you probably should replace the unloader bypass valve.
Here is a link to the pump.http://www.allpartsinc.com/mmAllParts/Others/A14292-001.pdf
Pull cord won't pull
I'ts a possibility that the engine has seized, remove the spark plug and look at it it will give you and indication if the engine is burned up.
My honda pressure washer runs put there is no
Check to see if you have an obstruction in the hose or tip. If clear you have a problem with the unloader valve. This valve sometimes gets stuck and continually recirculates the water not allowing you to build pressure. Sometimes you can remove and clean. If cleaning doesn't work you will need to replace it. Let me know how you make out.
No spray
I have a G 2600 VH psi which isn't listed here, I have need to order a part that isn't listed, this part goes into the detergent tank that monitors the difference between types of nozzle is attached to hose, what is it call?
Can't get water to come threw nozzel
Sounds like you may have some calcium buildup in the hose, gun or unloader. Take the unloader (where the hoses hookup) apart and clean away the deposits. This should solve your problem.
