Kodak Easyshare C813 Digital Camera Logo
Posted on Apr 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens problems my camera keeps saying "lens error 111,0,0,0" then "lens error 221,0,0,0". the camera is a kodak easyshare c813
  • Anonymous Mar 22, 2014
    How can you unjam the optical lens for a kodak c813 digital camera
SANDIP MISTRY
Level 2:
  • Expert 57 Answers
  • Posted on Apr 24, 2009
SANDIP MISTRY
Expert
Level 2:
Answers
57
Questions
0
Helped
14134
Points
143
There is a problem wit your lens section, get it repaired with your company professionals. Your camera may be fallen or being pressed from front side by someone. The new ZOOM will give the same best result and no further problems.
2 Related Answers
Anonymous
  • 6831 Answers
  • Posted on Feb 09, 2011
SOURCE: Kodak Easyshare CD82 lens error 111
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Anonymous
  • 6831 Answers
  • Posted on Aug 29, 2010
SOURCE: my camera kodak easyshare c813
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
1helpful
My Kodak EasyShare C813 keeps coming up with Lens Error 115,0,0,351. What does this mean?
Hello Branden, The problem is in the drive assembly. The drive gears strip and the pieces of plastic jam the motor causing the error codes. The camera is toast, Repair will be costly.
Best Regards, Russell
My Kodak EasyShare C813 says lens error 111000 evrytime I turn it on. And then it will shut itself off. What is wrong with my camera?
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
2helpful
Lens error 20e,1,0,0
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Camera wont turn on due to lens problem....
Same problem. I applied pressure to the extended lens by slightly twisting it from side to side. Hit the power button and the lens retracted and then extended again. The camera seems to be working properly.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
