Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Hotpoint aquarius washer dryer wd61 1100 Start any program and it appears to start correctly filling up with water the timer moves but the drum does not revolve. Its not the motor apparently because on two occasions of trying this it did revolve for about 6 secs then stops. The timer also seems to stop sometimes and does not start again. I can hear the Relay on the control PCB clacking away merrily but nothing happening. I think the timer is faulty and possibly the PCB, can replacement ones be obtained. Any ideas would be appreciated. Thank You
5 Related Answers
Carl Harries
  • 11 Answers
  • Posted on Feb 18, 2007
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Anonymous
  • 209 Answers
  • Posted on Sep 02, 2007
SOURCE: washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
A
Anonymous
  • Posted on Feb 24, 2008
SOURCE: Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Wayne Rees
  • 3 Answers
  • Posted on Dec 01, 2008
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Anonymous
  • 700 Answers
  • Posted on Jan 06, 2009
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
6answers
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
2helpful
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
1helpful
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
2answers
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
2answers
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
2helpful
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
