SOURCE: Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
SOURCE: Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
SOURCE: Have a Nikon D60 and after I take a photo, I get
You need to press the Disp/Display button to remove the settings on the display.
Testimonial: "Also had to use the multi selector to get rid of it. I now understand the process. Thanks"
SOURCE: My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
