What are you using on the HDMI cable. you may need to change the setting on that and not the tv. or you have the tv stuck in Zoom. if it is stuck in Zoom you will need to rest the tv back to factory setting.
Testimonial: "The tv is not stuck in zoom, already tried that, it happens in all of aspect ratio's settings. The HDMI cable goes from direct tv dvr box to the tv and in the settings on tv I have selected HDMI as my option over cable, satelite, or antenna. Also I have tried to reset to factory default settings to see if that would correct the problem and it didnt help."
SOURCE: I am trying to hook
to download the manual go to the link below:-
http://www.retrevo.com/support/Insignia-IS-LCDTV32-TVs-manual/id/8223ag521/t/2/
rate the solution
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
SOURCE: Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
