Line 6 Variax 300 Acoustic Guitar, Steel Logo
Tim Luttrell Posted on Aug 29, 2017
My Line 6 Variax 300 acoustic takes about a half hour to "warm up" before it functions properly. I half to believe that something in the circuitry has a soldering issue, or a specific part is failing. I have a very experienced friend looking into the problem (microscope and micro soldering capability), but no luck so far. I know the source is NOT the pre-amp. Sound familiar?
5 Related Answers
Anonymous
  • Posted on Apr 21, 2009
SOURCE: i'm looking for the variax 700 acoustic manual
Go to the Line 6 website <line6.com> and go to support, downloads. The manual is available in pdf format there.
Anonymous
  • 109 Answers
  • Posted on Jun 19, 2009
SOURCE: I have a variax 700 modelling acoustic guitar, On
I don't have a Variax but it sounds like an IC (integrated circuit) inside the guitar is getting hot and until it cools down, it does not function properly. Try the Line 6 website to find the nearest repair center. Good Luck!
larry james
Larry Stiles
  • 301 Answers
  • Posted on Jul 17, 2009
SOURCE: after hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Fred Yearian
  • 5603 Answers
  • Posted on Jan 17, 2010
SOURCE: Have a Line 6 Variax 300. Start to play for around
Sounds like it is overheating and protection circuit cuts it out.
Try putting a fan on it or driving it less hard.
Azrael SRL
  • 11800 Answers
  • Posted on Jan 26, 2010
SOURCE: a 700 series Line 6 Variax,noisy hiss
The hissing is caused by a bad connection, most likely at the cable jack. Try replacing it and while you're doing that check the rest of the components - especially the potentiometers, used ones generate a lot of static.
1helpful
Output of low E went dead (not 100%) but low in volume output and very dull sounding.
Here is a link that might help:http://line6.com/community/community/support/instruments/variax?view=documents&markAsQuestion=1
Variax 600 sound goes out then comes back if i
Check your battery. A weak battery will recover a bit when you power down for a brief period. Strumming hard will overcome the weak amplification when battery is down. Check that your battery is at LEAST 8 volts.
Also verify your plug into the guitar is clean. The barrel of the plug shorts to the ring contact to connect the internal battery. Do NOT use a balanced TRS cable for your intrument as this will lead to a marginal condition.
I bought aline 6 variax Acosutic 300
The variax models the sound of the pickups or microphone sound of various instruments. You should be able to hear the sound changing as you rotate the model knob. To get the best out of it you should try it with a line 6 floor unit which matches the pickup sounds with the right amp sounds. I think it could be quite subtle, but have a listen to the acoustic guitar sound then compare with the strat sound and the banjo sound and you should be able to hear the difference. I would love to have one of these guitars by the way!!! I have worked in the studio with a Danish pro guitarist who now only takes this on a session.
Have Line 6 Variax 700 6 String Modeling Guitar and the "A" String has a buzzing/humming coming thru the amp. This is in all model positions and alternative tuning positions as well. Have tried changing...
The frequency of the A string when in tune is 110Hz.
What you are hearing is actually 120Hz which is the second harmonic of the 60Hz power frequency. It would be hard for you to distinguish between 110 an 120.
Try this test: Bring something that produces a reasonable magnetic field such as a wall wart power adapter that is powered near your pickup... Then you will be able to see that you are picking up stray magnetic fields from your environment.
Humbucker pickups attempt to quash such pickup by winding the pickup so stray magnetic fields cancel in adjacent coils.
Some pickup CAN occur on your cord and also in an amp.
If you leave your cable unplugged from teh guitar you are LIKELY to pick up some of this hum... The second harmonic pickup is COMMON when devces like full wave rectifiers are driven by transformers in the area.
A 700 series Line 6 Variax,noisy hiss
1helpful
No sound fron some strings
Your answer looks like it can be found here:http://line6.com/community/community/support/instruments/variax Hope this helps. There are similar problems to yours listed and also factory reset procedures under Variax Troubleshooting Tips.
3answers
I have a variax 700 modelling acoustic guitar, On occations it just dies ie,no power or sound. I disconnect everything plug it all back up and still nothing. If I leave disconected for an hour or so...
1helpful
I'm looking for the variax 700 acoustic manual
Top Line 6 Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Line 6 Music Expert? Answer questions, earn points and help others
