20 Most Recent
Line 6 Variax 300 Acoustic Guitar, Steel Questions & Answers
Line 6 Low Down 400 bass guitar head
Make sure the volume and master volume are turned up. Try the amp with a different cabinet and a known good speaker cable. If you get sound, it's your speakers or your speaker cable.
If still no sound, you need your amp serviced.
10/20/2018 1:02:56 AM •
Line 6 Music
Answered
on Oct 20, 2018
Nearest authorized service center
First of all, it is never a good idea to post your full address online. At most, your Zip Code should be more than enough information for people to help find things like a service center.But, to answer your question, according to line6.com/service_centers, the closest shop to you is:Field Services4215 North 16th Street Building BPhoenix Arizona, 85016
8/19/2013 9:35:04 PM •
Line 6 Music
Answered
on Aug 19, 2013
Line 6 floorboard pedal switches dont work
Someone posted that removing the white plastic cover on the board-mounted momentary switches exposes the contacts for cleaning; I chose to drill a 1mm hole with a pin vise, as the cover is held by melted plastic tabs, then spray some DeOxit solution into the hole. It has worked for each switch I've tried on my 2 FB's (just found one in the trash today, w/the same prob). Good luck!
11/13/2012 7:43:41 PM •
Line 6 Music
Answered
on Nov 13, 2012
