Terry L Brown Posted on Sep 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having problem with Capture perfect software. Saved images in settings is checked and I can't uncheck it. It defaults back to checked.
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Dec 27, 2014
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247110
Points
823
I havent faced this problem. Try default option initially then try your settings. If this does not work, uninstall CP3 and reinstall it.
S. Mohan, India
2 Related Answers
A
Anonymous
  • Posted on Dec 05, 2007
SOURCE: scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Jun 23, 2008
SOURCE: Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Received this error while scanning: User cancelled operation Canon DR-9050C Driver Version 1.9.11303.26001 (-4526) File access error occured. Check write protect or disk full
Maybe the default folder that is set up to receive scanned images has been set as 'read only'.
This sub-folder will most likely be in your default user folder.
Look for something similar to 'Scans' 'Scanned' 'Scanned images'.
Right click folder name in Explorer to view / change properties. OR..
Your printer interface software should allow an option to change the save path.
Also check drive capacity in My Computer screen.
Uneven borders how do i fix it
If you are trying to do this by setting borders manually you are probably running into the Canon's minefield of "minimal printed borders" which throw off calculations. The manual setting is primarily for off-setting images rather than for perfectly centered images.
For a centered image, the borders are automatically set by the relationship of image sizing to paper size, with "center image" checked and other sizing options unchecked. This has worked perfectly in the three Canon printers I've owned, whereas trying to set even borders manually was always off a bit and a real pain.
If you want the same border width for all sides, the aspect ratio of the paper and image will have to be different, strangely enough, for all but square images. For 1" borders all around on 10x15 paper, e.g., your 2:3 AR image will have to be cropped and sized to 8X13" dimensions.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
I installed the Pixela Imagemixer and hooked the hadycam to the computer. Everything is fine accept the sound. How can I get the audio problem solved?
The currently bundled PIXELA software does not default to the correct audio settings. In the ImageMixer [Tool settings], confirm the USB Capture Device settings are set for an available [USB Audio Device]. This setting is not defaulted to the USB streaming mode.
The available USB audio device may be displayed as Sony Digital Imaging Device or USB Audio Device. When these choices are available, the Sony Digital Imaging Device should be selected.
If you are having any installation questions or problems with the PIXELA software, please let me know.
Thanks for understanding.
I dont have the disk for my web cam GE 98090 how can i get the driver ?
It says that it doesn't need a driver since it follows a universal driver included in windows. GE Perfect Image Webcam (1.3 Mega Pixels) Our Products: GE Computer Accessories > GE Webcams 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg2.jpg GE Perfect Image Webcam (1.3 Mega Pixels) (Click to see larger image and other views) hs.align = 'center'; hs.transitions = ['expand', 'crossfade']; hs.outlineType = 'rounded-white'; hs.fadeInOut = true; hs.dimmingOpacity = 0.3; //hs.numberPosition = 'caption'; if (hs.addSlideshow) hs.addSlideshow({ slideshowGroup: 'slides', interval: 3500, repeat: true, useControls: true, fixedControls: false, overlayOptions: { opacity: .75, position: 'top center', hideOnMouseOut: true } }); function pcf_initEnhancement(ele,img) { if (document.getElementById('1')==null) { hs.expand(ele, { src: img, minWidth: 250, minHeight: 250 }); } else { document.getElementById('1').onclick(); } } SKU: 98090 Capture clear videos and sharp images with the GE Perfect Image Webcam. More details... Price: $54.99
icoaddtowishlist.gif icotellafriend.gif addthis_pub = 'jascoproducts'; addthis_brand = 'Jasco Products'; addthis_options = 'favorites, digg, delicious, myspace, facebook, google, live, furl, reddit, twitter, ask, technorati, stumbleupon, more'; icobookmarkshare.gif Product Details Capture clear videos and images photos with the GE Perfect Image Webcam. Capture high quality hands-free audio and broadcast through the built-in microphone. The stand can easily be adjusted to your desktop or clipped to your laptop or monitor. Complete with ArcSoft® VideoImpression™ and PhotoImpression™ editing software to capture, edit and customize images and videos.
Features:
  • Built-in microphone
  • Snap shot button - Easy to use for great still photos
  • Hassle free focus - Ensures crystal clear videos with adjustable focus ring
  • ArcSoft® Editing Software (Included)
  • Adjustable stand - Steady base ensures stable videos
  • Compact size - Provides convenience and portability, perfect for travel and laptop use
System Specifications:
  • Sensor: CMOS with 1.3 MP
  • Resolution: up to 1280x1024
  • Video frame rate: 30 frames per second
  • Color depth: 24 Bits, RGB True Color
  • Focus range: 10 cm -- infinite.
System Requirements:
  • Computer with USB port
  • 350 MHz recommended
  • 64 MB recommended
  • Windows® XP SP2 or Vista
  • 100 MB free hard drive space
  • 16 bit video display or higher
  • CD-ROM Drive
  • Universal Video Class no drivers
1helpful
How do I print a TI-84 screen?
You can capture the screen by use of the TI Connect software.
  1. Connect the calculator to a computer using the TI Connect software.
  2. Run the TI Connect software.
  3. On the calculator, create the screen you want printed.
  4. While the screen is being displayed, go to TI connect main window and click the button SCREEN CAPTURE..
  5. Once screen is captured, save it.
  6. By default TIConnect saves captures in .bmp format, but you can change it to other formats by clicking the down arrow in Save AS window.
  7. Choose jpeg or appropriate format.
  8. Once saved, the image can be printed.
1helpful
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
1helpful
There are red blocks where images or pictures are suppose to be on all yahoo sites
hi,
Outlook Express comes with a default setting that blocks email attachments from being opened or downloaded. This can be overcome by clicking on Tools>Options>Security, and unchecking "Do not allow attachments to be saved or opened that could potentially be a virus." You also need to have "Block images and other external content in HTML email" unchecked.
Apr 09, 2009 • Yahoo Mail
S. Mohan, Chennai
2answers
Pictures to PC
HI,
Just uninstall the software without the camera plugged in and then install it again.Then plug in the camera.
Goodluck..
GeoVision
There is no way to fix this as a default
old marine
old marine
ZJ Limited
ZJ Limited
