my washer leaves standing water in the tub and I have to put on drain and spin to get the water out of the clothes. It's like it's not going through the entire cycle.my washer leaves standing water in the tub and I have to put on drain and spin to get the water out of the clothes. It's like it's not going through the entire cycle.
You can't post conmments that contain an email address.
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
I had same problem eventually the thing wouldn't go through a full cycle,I found a small piece of cloth was plugging off just before pump and letting water stand at bottom of washer which is what caused the water to stink.
This is a Maytagism for this style of washer. Quick solution... take a terry towel and wipe out the standing water in the front door seal area and when you're done, toss the towel into the wash load. Also make the loads a little smaller...it will keep the smell from reoccuring as much.
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
