20 Most Recent
Electrolux EW1000i Front Load Washer Questions & Answers
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
Electrolux EWF1074 with Error EH0. After 2 seconds
In case of error in the mains, or like what happend today at my house, the power lines went partially down, providing too low voltage, EH0 or EH1 will occour. If you also notice that the lightning indoor is somewhat dimmed during this error, the voltage is too low.
My front load washing machine is working but the water don't seem to enter.
First of all check filters in hoses & water valves, if ok then water inlet valve may be burnt out. Unplug power cord, remove top panel panel, check where 2 wires go to each water valve & check that area on valves for burning. If burnt or smells of burning, replace valve. IN SOME INSTANCES A COMPONENT BURN OUT CAN CAUSE DAMAGE TO CONTROL BOARD.
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it
? Thanks kindly
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
How to get the clothes to spin dry in Color wash mode?
Program the machine for white wash and turn down temperature and duration manually, and tune up the sentrifuge program to maximum RPM.
It helps to use a machine with large drum and minimum 1600 RPM. Large diameter of the drum is more efficient than a small diameter drum at the same RPM.
Error message e21
Machine tries to drain for 10 min (timeout) without emptying the tub.
Possible fault:
- drain pump
- drain filter
- drain hose
- wiring between drain pump and electronic
- electronic
Dado
