American Standard Evolution 2425V-LHO.020 White 5 Feet x Logo
Posted on Apr 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install of AS 2425 whirlpool tub
How to mark level line on studs when there is no access whatsoever?
(tub is closed on 3 sides with the exception of the small access panel in the apron)
Once that is accomplished, how much mortar might be required for a proper bedding? It appears in a drawing that is is quite thick, ie: several inches?
I would assume I should use rosin paper on plywood subfloor beneath mortar?
Is it a better idea to install all floor tile (including beneath tub) prior to installing the tub/cabinetry?
Appreciate the help much.
Thanks, Bill
Anonymous
Level 2:
New Friend:
  • Expert 92 Answers
  • Posted on Apr 15, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
92
Questions
0
Helped
71854
Points
144
Hey bill no easy way what we do is measure height of edge that will sit on stud and tack stud in tub area and dry fit tub.when you do that you can see how much space is under tub for your mortor you should use light weight cement called structolite its white and not as heavy and yes a piece of tar or resin paper is a good idea
I believe my Whirlpool tub is shutting off because of a vacuum line to the on and off switch is that a vacuum line should it be clear of water for should it have water in it
it is not a vacuum but a pressure line
as the water in the tub rises
it makes pressure against a diaphragm in the water level switch so when the pressure exceeds the setting , the switch closes of the water solenoid and starts the wash
it works better if there is no water in it
No problem as yet. Just purchased a whirlpool front load top of the line. The instructions are very good except I can't find any instructions regarding adjusting the water level for smaller and la
For the Whirlpool WFW96HEAC front-load washer, the water level adjustment is made by the washer based on the size of the load. If only 3-4 items are in the tub, it will do a small load. If you fill the tub completely, it will do a large load. (Note: if the clothes are packed into the tub, they can't tumble and won't get cleaned.) Loading the tub with clothes until it is 1/2 or 3/4 full are the other load sizes.
Please add a comment with the model of your washer, I'll be glad to give additional help. I hope this helps.
Whirlpool does not turn on. Kohler Model K-1474-V
The chances that is problem you are experiencing is related to the suction cover is extremely remote. The suction assembly doesn't have anything to do with the tub motor operating.
The issue is most likely with the motor not working or the air switch in the motor malfunctioning.
What does the control look like that you use to turn the pump on/off?
Is it an air button or an electronic switch?
Jan 29, 2013 • Kohler Home
1helpful
How to remove a transmission for a 2002 GMC Yukon
Removal & Installation 4L60E/4L65E To Remove:
  1. Remove or disconnect the following:
    • Transmission fluid
    • Transmission oil level indicator tube and seal from the transmission
    • Plug the oil level indicator tube opening in the transmission.
    • Remove or disconnect the following:
    • Shift cable end from the transmission shift lever ball stud
    • If equipped with a transfer case, remove the front propeller shaft.
    • Rear propeller shaft.
  2. Plug the transmission oil cooler line connectors in the transmission case.
  3. Remove or disconnect the following:
    • Starter motor.
    • Transfer case, if equipped.
  4. Support the transmission with a transmission jack.
  5. Remove the transmission mount nuts.
  6. Remove the transmission crossmember.
  7. Remove or disconnect the following:
    • Torque converter access plug 4L60E/4L65E removal 9308kg37.gif
    • Flywheel to torque converter bolts
    • The two bolts securing the transmission rear mount to the transmission
    • The transmission vent hose, fuel lines, and the wiring harness from the transmission
    • The stud and the bolt securing the transmission to the engine
    • The six studs and one bolt securing the transmission to the engine. Install tool J21366 onto the transmission bell housing to retain the torque converter. Pull the transmission straight back.
    • The transmission from the vehicle
  8. Flush the transmission oil cooler and cooling lines when you remove the transmission.
To Install:
  1. Install or connect the following:
    • Tool J21366 onto the transmission bell housing to retain the torque converter.
    • Support the transmission with a transmission jack.
  2. Raise the transmission into place and remove the tool from the transmission.
  3. Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must be flush onto the flywheel and rotate freely by hand.
  4. Install or connect the following:
    • Six studs and one bolt securing the transmission to the engine. Tighten the studs and the bolt to 50 Nm (37 ft. lbs.).
    • Stud and bolt securing the transmission to the engine. Tighten the stud and the bolt to 50 Nm (37 ft. lbs.).
    • Flywheel to torque converter bolts. Tighten the stud and the bolt to 46 Nm (63 ft. lbs.).
    • Torque converter access plug.
    • Transmission vent hose, fuel lines, and the wiring harness to the transmission.
    • Two bolts securing the heat shield to the transmission. Tighten the bolt to 17 Nm (13 ft. lbs.).
    • Two bolts securing the transmission rear mount to the transmission. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Install the transmission crossmember. Tighten the nuts and bolts to 70 ft. lbs. (95 Nm).
  5. Remove the transmission jack from the transmission.
  6. Unplug the transmission oil cooler line connectors in the transmission case.
  7. Install or connect the following:
    • Starter
    • Transmission oil cooler lines to the transmission
    • If equipped with a transfer case, install the front propeller shaft.
    • The rear propeller shaft
    • The shift cable end to the transmission shift lever ball stud
  8. Unplug the oil level indicator tube opening in the transmission.
  9. Install the transmission oil level indicator tube and seal to the transmission.
  10. Tighten the oil pan bolts and fill the transmission with transmission fluid.
  11. Lower the vehicle.
4L80E/4L85E To Remove:
  2. Plug the oil level indicator tube opening in the transmission.
    • Shift cable from the transmission shift lever ball stud
    • If 4WD vehicle, remove the propeller shaft.
    • If RWD vehicle, remove the propeller shaft.
    • The transmission oil cooler lines from the transmission
  4. Plug the transmission oil cooler line connectors in the transmission case.
  5. Remove or disconnect the following:
    • Starter motor
  6. Support the transmission with a transmission jack.
    • The two bolts securing the heat shield to the transmission
    • One nut and one bolt securing the transmission brace to the engine bracket and transmission
    • The two bolts securing the torque converter cover to the engine
    • The four bolts securing the torque converter cover to the transmission
    • The six flywheel to torque converter bolts
    • The two bolts and nut securing the transmission rear mount to the transmission
    • The stud and the bolt on the right side securing the transmission to the engine
    • The remaining six studs and the one bolt securing the transmission to the engine
    4L80E/4L85E removal 9308kg36.gif
  8. Pull the transmission straight back. Remove the transmission from the vehicle.
  9. Flush the transmission oil cooler and cooling lines when you remove the transmission.
To Install:
  2. Support the transmission with a transmission jack.
  3. Raise the transmission into place and remove the tool from the transmission.
  4. Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must be flush onto the flywheel and rotate freely by hand.
  5. Install or connect the following:
    • The stud and bolt on the right side securing the transmission to the engine. Tighten the stud and the bolt to 50 Nm (37 ft. lbs.).
    • Six flywheel to torque converter bolts. Tighten the bolts to 60 Nm (44 ft. lbs.).
    • The two bolts securing the torque converter cover to the engine. Tighten the bolt to 50 Nm (37 ft. lbs.).
    • The four bolts securing the torque converter cover to the transmission. Tighten the stud and the bolt to 33 Nm (24 ft. lbs.).
    • The transmission vent hose, fuel lines, and the wiring harness to the transmission.
    • The two bolts securing the heat shield to the transmission. Tighten the bolt to 17 Nm (13 ft. lbs.).
    • The two bolts and nut securing the transmission rear mount to the transmission. Tighten the bolts and nut to 25 Nm (18 ft. lbs.).
    • The flywheel to torque converter bolts.
    • One nut and one bolt securing the transmission brace to the engine bracket and transmission. Tighten the bolts and nut to 50 Nm (37 ft. lbs.).
  6. Remove the transmission jack from the transmission.
    • Starter motor
  8. Unplug the transmission oil cooler line connectors in the transmission case.
  9. Connect the transmission oil cooler lines to the transmission.
  10. Install or connect the following:
    • The transfer case
  11. Unplug the oil level indicator tube opening in the transmission.
  12. Install the transmission oil level indicator tube and seal to the transmission.
  13. Tighten the oil pan bolts and fill the transmission with transmission fluid.
  14. Lower the vehicle.
1helpful
Bathtub installation
Now I see the wood stud is added support and the tub should rest on it. though it is not to hold the tub up. Like a man using a cane the cane doesn't keep a man standing by itself. Rather it helps a person be more stable that's what the stud does. Set at height for a level tub.
Here is a trick as well for supporting the back of the tub (Shimming) Get some of the expandable foam. Set everything in place like the wood ledge when you have everything in place and tub pre-fitted. Remove tub and place a line of foam along back side. Place tub in place and when foam expands and dries it will become your perfect shim. Hope this helps, thanks for using FIXYA. Good luck, Jeff
Apr 08, 2010 • Maax Home
Need to replace tub in old travel trailer. any help for removing old one, installing new one and supporting under floor if rotted??
First turn off water then remove the wall board ,or paneling at least 12 in above tub lip .,Remove more if you can.The more room you have the easer it is to slide the new tub into place. Now you should be able to reach the tubs drains unsrcew or cut them out When you have the drains disconnected .pull any nails or screws from around the tub. Look at the path you have to take to get the tub out ,you'll probably have to remove the toilet tubspout or maybe even the lavitory.when your path is clear put a flat bar between a stud and the inside edge of the tub pry the tub up and out. You way have to move from one stud to another.When its off the wall on the inside edge see if you can pick the back end of the tub up.This should make it easier.Remove all the bad flooring .You will need some lumber now replace the floor joist or scab onto them (you will need 3 or 4 ft of good joist on eather end to scab onto.If the edges of the new floor board dont land on a floor joist simply nail aboard onto the side of the joist it needs to meet on level with the other joist.Where the front of the tub sits cut a hole out about 10x12 in center of hole14and1/2in for standard tub and off the wall in front of the tub 12 in.This will give you room for the tub shoe(thats the part the tub basket screws into) Sit tub on flat level surface and measure from the ground up to the inside edge of tub .Nail a 2x4 on the inside wall about 4 ft long off the floor as high as the edge of the tub.Take your time and get this right if you dont you will have to pull the tub back up after you've set it in place..If you have room you can put the waste and over flow on the tub follow the instructions on the package use pipe compound on threds and plumbers putty on the basket lip.If your not going to be able glue the trap after the tub is inSet the center of drain 14 1/2 in off inside wall and 1 1/2 off front wall .put tub into place front in first drop down the back and slide tub ont the board you nailed up earlier level it up dont add pitch the tub has pitch built into it takes screws or roofing nail securing tub to studs hook up the drain P.S.dont nail or screw through the tub instead nail or screw just above the top liof the lip fill the tub completly up .plug up the over flow When water gets to edge of tub lip look fore leaks then release stopper and finish looking for leaks . YOU HAVE A LOT TO DO! Good Luck!!
Dec 02, 2009 • Home
4helpful
Where is the windshield wiper motor on a 2007 Dodge Caravan and how do I replace it?
Wiper Motor: Service and Repair
Removal
REMOVAL
The front wiper motor comes as a unit with a wiper pivot on each end and mounts to a shaft that holds these two inner pivots.
1. Disconnect and isolate the battery negative cable.
2. Remove the wiper arms.
3. Disconnect the washer hose at the in-line connector located near the air cleaner housing.
4. Lift the cowl grille and disconnect the washer hose grommet from the hole in the wiper module. Pull the washer hose and the grommet
completely through the wiper module tub hole.
5. Remove the cowl grille.
CAUTION: Be careful not to scratch the cowl grille on the corner of the hood.
6. Remove the four brace nuts holding the wiper tub to the lower windshield fence.
7. Remove the four bolts underneath the wiper tub inner brace holding the tub to the bulkhead.
8. Remove all four inner support brace mounting nuts and pull the inner braces just free of the mounting studs.
NOTE: The wiper tub will drop down slightly.
9. Disconnect the driver and passenger side wiper link ends at the inner pivots.
10. Remove the two left wiper motor assembly mounting nuts.
11. Remove the two right wiper motor assembly mounting nuts.
12. Partially lift out the wiper motor assembly out of the wiper tub.
13. Disconnect the wiper motor electrical connector.
14. Remove the wiper motor assembly the rest of the way from the wiper tub and remove from vehicle.
Installation
INSTALLATION
1. Install front wiper motor assembly onto wiper tub.
2. Connect the electrical connector to the front wiper motor assembly.
3. Install the four mounting nuts. Tighten nuts to 9 Nm (80 in.lbs.).
4. Push the four inner support braces onto the studs and install the four nuts. Tighten the nuts to 9 Nm (80 in.lbs.).
5. Install the four bolts underneath the wiper tub inner braces that hold the wiper tub to the bulkhead. Tighten the bolts to 17 Nm (150 in.lbs.).
6. Install the four nuts holding the wiper tub to the lower windshield fence line. Tighten nuts to 7 Nm (65 in.lbs.).
7. Apply grease to drive link bushings.
NOTE: Make sure to use Mopar(R) approved grease.
8. Attach the driver and passenger side outer wiper linkage to the inner pivots on the front motor assembly and firmly snap into place.
CAUTION: Do not apply too much force to engage link bushing or damage can occur to the drive link bushing.
9. Position the cowl grille in place.
10. Install the washer hose and grommet into the wiper tub.
NOTE: Be sure to properly seat the washer hose grommet into the bottom of the wiper tub.
11. Connect the washer hose at the in-line connector located by the air cleaner housing.
12. Install the cowl grille.
13. Connect the battery negative cable.
14. Verify that the wiper motor is in the Park position by cycling the wipers system. When done, remove keys from ignition.
15. Install the wiper arms.
16. Align the wiper arms and tighten nuts to 35 Nm (25 ft.lbs.).
17. Install the wiper arm nut caps.
1helpful
American standard whirlpool tub #2425
Here is the link to installation instructions:
American Standard #2425
The information you need is on page #7.
Hope this helps!
Oct 24, 2008 • Home
3helpful
2answers
How to Install Toilet Paper Holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
