SOURCE: how can i make the date of my tag heuer formula 1
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
SOURCE: cannot pull the knob out, to change the date and
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
SOURCE: how do i change the date on my tag heuer formula
You change the date the same way you change the time. The only difference being pull the crown out 1/2 way to the first click instead of all the way out.
Testimonial: "Thank you very much!"
