Casio AP-620 AP620 Digital Cabinet Piano Black Logo
A
Anonymous Posted on Sep 02, 2013
Casio ap-620 please wait - Casio AP-620 AP620 Digital Cabinet Piano Black
Reuel Teoh
Level 2:
Champion:
  • Casio Expert 411 Answers
  • Posted on May 18, 2014
Reuel Teoh
Casio Expert
Level 2:
Champion:
Answers
411
Questions
Helped
112781
Points
490
The main circuit board has failed. Will Cost about 300-400 dollars to replace if not still under warranty.
1 Related Answer
Anonymous
  • Posted on Mar 08, 2011
SOURCE: Our Casio Celviano AP-620 won't
My AP-620 has a pedal problem too... it sticks and I keep hearing the music I play ring out after the pedal is relaesed
2answers
Casio Cleviano model AP-3. Where can I download a repair service manual?
Hi :). Are you referring in Casio Cleviano model AP-33? Because i try to search for Casio Cleviano but there is no result. the only available is the model for Casio Cleviano model AP-33.
Casio AZ 1 Service Manual Parts List Page 6 . I hope this link can help you to find out the manual for your casio model. thanks
Feb 25, 2016 • Casio Music
Connecting to garageband
Only newer models with class-compliant USB (made last 12 months) can connect to MACs - & IPADs and PCs.
Older models require drivers available only for Windows.
Casio piano seems to be frozen
It is 3 years/5 years warranty depending on your country.
Call CASIO warranty or contact dealer.
My Casio AP 620 Celviano says "Loading" soon as I switch it on but is not working
Could possibly power supply problem. If you're running through a multi-board, try running directly into the outlet. Failing that, try another power outlet altogether.
The Celviano range aren't real power hoggers once going, but initialising and starting up takes a bit of omph.
Every is out of tune
There is a POT at the back of the keyboard to tune the keyboard.
Download "AP tuner" to your laptop to help you tune. If you use a desktop PC, you need to connect a good microphone.
1helpful
Ok i was playnig on my celviano ap-620 and then 8 of the keys started to sound rare, very loud, it seems like it lost the key touch sensivility on those keys from the center (C) and 8 keys down i tried...
What has happened is that one signal wire of the matrix that scans the keyboard has opened up. Each key has two contacts. One closes before the other and that is how they measure key velocity to control the loudness for piano sounds for example. When one contact doesn't work, often the sound is set to MAXIMUM key velocity resulting in MAX loudness. The key contacts are scanned digitally in groups of usually 8 or 12 and, for instance, every C key has a single line attached and then every group of 8 or 12 has a second line and then there are two complete sets of these to implement the velocity sensing. Your unit probably has either a break in a cable or possibly a cable connector that has failed or not seated OR worst case, the circuit board under the keys has a crack breaking one wire or circuit trace going to that section of the keys. The problem will require opening the keyboard to repair. If you are not electronically adept, besst to take this to a repair shop.
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
