Disappointing indeed. Did you buy it new or secondhand? If new, it is under manufacturers warranty. Husqvarna are reliable machines.
If it is used, undo the screws on the bottom of the foot pedal and you will see a wire track. Spray it with electrical switch cleaner. You can spray the button as well.
the brand is immaterial what is important is the farad rating and the voltage
farad reading is expressed a PF or UF
if none of that is available find the voltage and amp rating from the plate on the motor and take the old capacitor to an electric motor repair shop for identification
Could be the switch, but it sounds like the motor is going bad. However, I dont know if you tried to lubricating the tracs. Some of these seats are on ball bearings and some on nylon bushings, either way they need to be lubricated once in a great while. Have you tried to help the seat to move by pushing in the direction it is going to see if it speeds up. If so, the seat motor is going out or the tracks are binding up. I hope this helps.
Singer
Featherweight II, Featherweight 117 & Featherweight 118 Sewing Machine ManualPrinted B/W manual to USA or Canada address. Free
Shipping
$12.00
Printed B/W manual to all other countries. Free
Shipping
$17.00
Click image to enlarge
Download Copy
$ 5.0
Pls check if the intercom function works. If yes, then the base is
simply waiting for the presence of a dialtone on the telephone line. It
would be required to check your telephone wire connections. Further, if
you have an extension telephone, pls verify that indeed you have
dialtone along the same line. In most instances, you may need to
contact your phone provider to verify service.
If no intercom function, it may simply need pairing again or redo the initial install setup.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
To my knowledge Panasoni Error Code H03 indicates mechanical failure, more specifically, the traverse servo motor. Simply stated, the eye cradle could no longer slide back and forth along the slider bar. Corrective measure requires cleaning and application of appropriate light lubricant. Vaseline oil would do for the time bieng. Pls refer to the diagram below.
