20 Most Recent
York Barbell Home Use Fold-Up Treadmill Questions & Answers
Hi just wondering if anyone can help with a
hi,
Error E3 means speed sensor error.there is a sensor for checking and controlling the speed. check the speed sensor and its,connectors, clean the speed sensor. for that u have to open the motor cover.
ok
Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Cracked deck
I bought a second-hand York Inspiration,
and it developed the same problem. Upon dismantling the treadmill,
I discovered the deck was cracked in two areas. My solution was to
put a section of chipboard over the crack on the underside, securing each
section with 12 screws. I used 16mm board. I cannot remember
the other dimensions of the board, but it needs to fit between the deck
support rails lengthwise, and widthwise between the screw holes for the
foot rails. It is best to tape the edges of the boards to ensure
they don't shed any debris once fitted.
The Inspiration manual contains an exploded
diagram to assist with dismantling the treadmill. If you do not have one,
it is available as a PDF on the web.
It's fairly straightforward to dismantle
the treadmill.
The only part of any difficulty is the
foot rails; once the screws for the foot rails are removed they stay put,
as they are stuck down with strong double sided tape. Ease them off
gradually. Once you have removed them, mark the front of each with
a bit of tape, as the screwholes are not symmetric.
Comes up err when u turn it on in the speed window, and wont even move
Adjust the Speed Sensor:1)Make sure the sensor Speed is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; 2)make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.sincerely.E.CUADRAMANAGUA,NICARAGUA.C.A
