Refrigerators Logo
Anonymous Posted on Aug 30, 2013
Frigidaire r134a Frigidaire top mount (2009/model number label blank) Freezer not freezing, removed back panel in freezer, frost buildup all the way up and around the capillary tube. The frost is only on the bottom tube of the evaporator up to the capillary tube.
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Refrigerators Master 518 Answers
  • Posted on Apr 25, 2017
Marat Brikov
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324562
Points
3123
5 Related Answers
applianceboy
Todd Marr
  • 77 Answers
  • Posted on Sep 26, 2007
SOURCE: FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Anonymous
  • 213 Answers
  • Posted on Nov 29, 2007
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Anonymous
  • 51 Answers
  • Posted on Jan 14, 2008
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
shaxaman
  • 13 Answers
  • Posted on Aug 10, 2009
SOURCE: upright freezer - bottom freezes, top won't
check the drain system may have got blocked....
Anonymous
  • 255 Answers
  • Posted on Sep 24, 2009
SOURCE: I have a top-mount Frigidaire Gallery frost-free
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
2answers
Where is the drain located on Frigidaire model r134a? is it the hole on the bottom freezer side?
R134A is not the model number. This is located inside the freezer on a white sticker on the left or right wall. Anyways, the drain is going to be located inside, behind the back wall of the freezer on the floor, directly below the Evaporator coils where all of the "cold" in your entire box is created. If you're referring to a refrigerator, there should be an aluminum tray/pan that all the defrost water drains down into. Sometimes they just freeze over & the hole becomes plugged w/ice. Hope this helps. Tips appreciated. Have a great weekend :)
Mr. All-Star
Model FCD-123 Frigidaire malfunction
2 possible issues .evaporator fan motor is not working.you should be able to hear it in freezer.auto defrost is not working and vents are clogged with ice.look for ice/frost buildup on freezer wall///floor
Frost Buildup on Top Shelf lower shelves aren't freezing
This link might help you troubleshoot
Freezer Frost inside Symptom Diagnosis Sears PartsDirect
The lucky solution is if the door seal or inner plastic liner need to be placed/repaired (this lets warmer air into the freezer causing frost and poor cooling).
But you can also see from the link that your symptoms could be caused by other electronic related things...more of a challenge to fix...
Helpful?
Good luck on your troubleshooting
Frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Jun 14, 2008 • Freezers
My Frigidaire side-by-side fridge (model: FRS24XGCW2) never reach freezing temperature in freezer though both side are colder than room temperature. The compressor and fan keep working forever.
1. Check and clean the condenser where system heat is transfered to the air. Located in back behind removable panel, after cleaning make sure you re-install the panel for proper air circulation.
2. Check the back wall of the freezer for ice or frost. If you have frost buildup on the back wall you have a defrost system problem. This would be lated to the timer, heaters, or defrost thermostat.
2helpful
T
1helpful
2answers
Ice in the bottom of frigidaire side by side frost proof freezer
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
