Anonymous Posted on Aug 29, 2013
How do I clear Lanier 5222/5227 error code sc392?
  • Anonymous Aug 31, 2013
    Thank you Everette Lin. By the way, what is and where is the corona cleaner located?
1 Related Answer
Everett Lin
  • 990 Answers
  • Posted on Oct 16, 2009
SOURCE: have a lanier 6735 with an ''A1''Code
Hello sir; A-1 code means discharge corona cleaner problem, check it up may be the cleaner not function right.
1helpful
2answers
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Why error code sc204 is on a lanier ld533c?
That code is usually a problem inside the laser unit - the polygon mirror motor.
Lanier 540c printer
IH inverter current error at power on. Either the fuser is damaged or the invertor coil is defective. You really should have a Ricoh tech look at that one. It is not an easy fix for the layman.
1helpful
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
1helpful
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
2helpful
2answers
What does Service code SC548 on a Lanier LD435c stand for
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
9helpful
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
