SOURCE: dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
SOURCE: DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
SOURCE: Dewalt 51488. Air leaks around trigger and won't fire nail.
Go to Dewaltservicenet.com and download a breakdown of the tool before starting. I would recoment changing all the O rings and make sure that you get a good grease to lube them first. Its not that hard.
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
